dash lights not working
hi the dash lights on our mk1 are not working is there a fuse for this or where does the pod on the dashboard plug   in to cannot not see any loose wires all other electrics are working so any thoughts on this thanks
Look for a blue plug with 3 thin wires behind the switch blanks to the right of the steering column. This needs to be plugged in to the dash dimmer switch, if fitted or a switch blank with a shorting bar in it.
Hi had a mk1 and same thing happened to me be aware that when my dash lights went my tail lights also didn`t work Mine was a fuse that had gone check relevent one and possibly replace. sorry cant be any more help than that.
the blue plug was out thanks all working now
Glad all sorted. and Robbie came to the rescue
