Is your MX5 pulling in one direction when braking or is your tyre wear uneven?
If the answer to any of the above is yes, then here is the solution for your MX5, so it will drive like it is on rails afterwards
On Sunday 15th October we will be visiting Wheel Alignment Solutions, where Darren & Russell will conduct 3D Wheel Alignments, using the SUPERTRACKER™ System.
Darren worked at SUPERTRACKER for some years, along with Nick the previous owner of the business and knows the system inside out and understands car steering & geometry. They both had considerable input into the design of the system, so Darren knows his subject and the results are absolutely incredible
Last year, 2022, Darren said the cost could be a cash only event, at £50/car, unless they come up against a problematic alignment requiring more attention, then it will be their usual rate of £70/car, which is their normal charge for a 4-wheel alignment.
Once done your MX5 will drive like it is on rails and you will definitely notice the difference
Darren has just confimed that the cost will be the same (£50) as in 2022, so we a good to go
I am running a list, given below, to track numbers, so if you wish for your MX5 to be tracked by an expert in the field, then please reply to this forum post only and I will add you to the list.
Please note, the list below, will be the running order of the day, so if you have a burning need to be away early let me know and I will do my best to accomodate you.
Finally, last year there were some cars that were very difficult to adjust and required lots of effort by Darren and Russell, applying copious amounts of penetrating oil and heating nuts and bolts with a welding torch to free them off without shearing them off, which burnt up a lot of time and meant it became a long day for everyone. So, if you are coming along, please take time to give your MX5 front track rod alignment nuts and front+rear castor adjustment bolts a good couple of doses of penetrating oil between now and then to ensure that your MX5 can actually be done on the day
Best Regards
Mal
List of Attendees/Can make new date
- Phillip Katz / Yes to 12th Nov
- Elliot Redding / Yes to 12th Nov
- Gregg Walker / Yes to 12th Nov
- Steve (Whitebeard) / Yes to 12th Nov
- Colin (SCORPS) / Yes to 12th Nov
- Jane Heyer / Yes to 12th Nov
- Tim Dalby / Yes to 12th Nov
- Mal Rowland / Yes to 12th Nov
- Ash Chance (Observer)
