Im trying to get an accurate reading from my dipstick but seem to get different readings depending on how long the engine is switched off for! When is the best time to check it after i’ve switched the engine off?
That’s because the oil settles overnight, once you start the engine the oil starts sloshing around.
If it’s on the low end of the dipstick, add 1/2 litre and wait 10 minutes to see how far the level rises
Yep, 0.8L from low to full (says it on the dip stick between the marks). With the engine up at operating temperature, check the oil level with the car on level ground 5 mins after turning it off.
Was hoping I was supposed to check it 5 mins after I turn the engine off!! If I do that (after 30m journey) if shows loads but in the cold frosty morning it doesnt seem to show any!!! Is that normal?
No, that’s not normal. Waiting 5 minutes to take a reading is just so the oil has time to drain back to the sump. So the oil level is expected to rise when the car’s stopped. It shouldn’t fall.When you take a reading, do you wipe the dipstic clean and try again? Trying 3 or 4 times over is the only way I find I get a consistent, dependable reading.
If I wait 5 minutes and then check the the oil level, its at 3/4 full or very nearly full but checking it this morning (after only moving it out of garage) it didnt seem to show any. I did wipe it clean and try again but only tried once, will try it again a few times next time!
It defo seems to get lower on the dipstick the longer I leave the car without using it. Does that mean its just low on oil or some other problem? It was serviced about 7k ago and will have another one in 2k.
You have to wait 5 minutes after stopping the engine. Driving the car out of the garage will spread the oil all around inside the engine, and you have to wait for it to run back to the sump.
Will check it again before moving it out of garage tomorrow!!! I checked it before at work (engine has been off for 3 hours) and it was just over the Low mark. As it should be read higher when left, I assume thats very low and needs topping up?
