I bought these from a U.S. supplier. They were about £77 delivered with no customs or VAT added. Took about 3 weeks to get here.
The picture above is for the ND without the rear cosmetic skirt, there is extra tape on the ones to fit my ND2
The front flaps fit with the existing plastic connectors, the bottom one being exchanged for a longer type (supplied with the flaps)
The rear flaps are suck in place with 3M heavy duty tape BUT I have not fitted these yet as the outside temperature is a little low and it needs warmer weather to cure the adhesive, so these will be fitted in a few weeks (hopefully it will get warmer!)
The front flaps took less than 5 minutes to fit - you DO need a trim removal tool if you value your finger nails or skin. My cheapie plastic ones from Amazon (<£5) worked well.
To install, turn the wheels to point right to fit the right hand flap and left to fit the left one. That’s about as technical as it gets.
Before
After
Some pics of the flaps in place - hardly noticeable once in place and unless looking, I doubt if you would notice them.
As mentioned, the rears will be fitted when the weather gets better. I may insert a fixing as well, do I trust 3M tape that much??
Yes, the drive needs weeding and that’s on the list to do.
Rears will look like this . . . .
