Does the ND have sill drain holes?
  1. My model of MX-5 is: MK4
  2. I’m based near: Manchester
Whether the ND has sill drain holes? Not roof drains but for the sill. On a MK1 they used to be either side of the jacking point.
Thank you
Yes it does. They’re not visible looking at the bottom of the sill from a kneeling down position, but if you raise the car to look at the back of the seam from underneath they are easier to spot. Make sure they’re not blocked if a previous owner has treated them internally with an anti-corrosion product. Easy to poke clear with the pointy end of a very small unused zip tie. I think there are 4/5 on each side.
Brilliant, thank you very much. I will take a look.
