New to site…How do get to the micro switch on the door barrel? Read loads of posts but none seem to clearly identify how to change micro switch on drivers door… cheers
Be careful when removing.
The microswitch clips to the lock barrel but the plastic is quite brittle.
I usually ease the bigger clip up off its lug with a precision screwdriver blade and then do the same with the smaller clip.
Have removed dozens without breakage but seem to remember broke one a while back.
Hi… Do you have to remove anything specific from the door… seems difficult to get to?
You have to remove the door card.
The handle is a bit of a fiddle as over to one side but 2 x 10mm nuts undone and it comes away.
The switch is connected to a cable o/s = red, n/s = yellow or is it the other way round?
Clipped to door with three black plastic I don’t know what you call them fixings and then a white plug to loom.
Why do you need to remove it, has it stopped arming alarm or central locking packed in?
When I open drivers door it sets alarm off…passenger door is fine and lights flash when alarm is set…tried a bit of wd40 in lock but with no success…
The two 10mm nuts hold the lock in place?.. are they protected by polystyrene?
I have exactly the same problem and managed to source a second hand micro switch assembly. Just tried to fit it and ran into a few problems. It’s fairly easy to remove the door card but I can’t figure out how to get to the lock end of the assembly as it is behind the metal doorframe! Any ideas appreciated
If you locked the car with the remote and then opened the door with the key, then yes, the alarm will go off. It’s not a fault; designed that way. It’s intended the car is locked and unlocked with the coded remote. The door lock doesn’t have the means to recognise the key chip, so the system is designed to assume that opening the car with a key is an attempted break-in. The alarm will stop when you put the key in the ignition. Solution; always use the remote.
JS
Thanks for the reply JS… The car does not have a remote only alarmed through the key activation…need to replace micro switch Mazda have informed me… OK on passenger door but not drivers door.
Whiskeymac… that’s my problem there must be easy way to get to micro switch… hopefully?
Let’s hope so, meanwhile I guess we have to use the passenger door lock.
No problem. I wasn’t sure whether your car had remote locking and the unexpected alarm can surprise owners with such cars. It certainly appears your car is not recognising the operation of the lock barrel so the fault probably is the microswitch.
JS
