ECU location???? MX5 MK1 eunos 1.6
 Can someone tell me where my ECU is?
The Haynes manual said it was behind the passengers seat, I have looked there, it’s not. I looked in the boot behind the passengers seat, after removing the panel, not there. I took out the glove box, not there. Not behind the drivers seat.
Please help, driving me mad.[:@]
Pete
 Where in the footwell? Is it on the left behind the little plastic cover? Bottom corner of “A” pillar?
-or there is a hole rusted inthe floor and it has fallen through?! Check to see if it is hanging under the car… [:P]
Seriously though. It is simple enough to find. Roll your passenger seat all the way back and peer underneath. A torch will help. If taking the seat out helps its only a few bolts, if you need to change the ‘brain’ it will be a lot easier.
 Thanks for the info, will have a look.
Pete[:)]
 Thanks Joanne,
It was right where you said, behind a plate where the feet would rest. At last.[Y]
Cannot believe the time that took to find.
Now all I have to do is check the wiring[*-)]
Pete[:D]
