Unless you are going to use your car mainly on the track I would go for the 30mm Eibachs. They will hardly make any difference to the ride (especially if your car is fitted with the Bilstein shocks) and will greatly improve it’s looks and handling. I had my ND fitted with the Eibach 25mm/30mm lower springs and they were great without seriously compromising the ground clearance.
Seems like the 30mm springs are the way to go then. Does anyone have any pictures lowered on these but on 16 inch wheel? All the images I can find are on 17s…
Hi, I have -30’s on my NC1, and the only time I have an issue is when me & the Mrs go away for the weekend and we both have a weekend bag in the boot  & a full tank of fuel. (see photo)
The springs were on when the 16’s were fittedO, so no. Depends what you want, you asked for pics of cars with the springs fitted, I’ve given you two wheel sizes as well. TBH, the rolling radius of each wheel size is almost identical as the bigger wheel has a lower profile tyre? Speed humps/bumps/ramps etc were not an issue, never went lower so can’t comment on that aspect with a bigger spring drop.
I appreciate your help mate, just really keen to pick the  right springs for me first time. I’m 90% sure the  30mm ones are the ones to get. I just don’t want to fit them and wish I’d have gone that little bit more. The fact I’m on 16s I think will highlight any arch gap more than the 17s would (despite the size comparison).
A little on speed humps, more so with two in the car. Comfort wasn’t an issue, but you tend to drive waiting for the noise as it bottoms out. I have 30mm on my current 5 and they are much better, I’ve only bottomed out once and that was at speed on an uneven road as I hit a horrible dip.
