electric hard tops for mk3
hi all
 I want a hard top for my mk3 :slight_smile:
I see loads on ebay for approx. £200   all are electric
would they fit my non electric?   obviously I know the wiring and motors wouldn’t work without a lot of hassle…but would the hard top fit ?
cheers
I believe the back half of the coupe version has different body panels including the boot. So not without a huge transplant job.
Yes the rear of the car is slightly different to make it fit / work.  Here’s a quote from the technical site: Packaging a retractable hardtop mechanism into a small car like the MX-5 required a new rear section of the bodyshell and new bootlid. This gives the RHT a different roofline and enlarged rear end compared to the soft top models.
http://www.roadster.blog/2013/08/the-retractable-hardtop.html
i guess that’s why the huge price difference !!:slight_smile:
This thread is confusing - what exactly are you seeing on eBay for £200?
A Mk3/NC detachable hardtop is probably around £500 or more at this time of year. It will have a heated rear window - is this the electric bit you are referring to?
The Power Retractable Hardtop or PRHT is part of the roadster and can’t be retro-fitted to a soft top (nothing is impossible but why you’d want to?) without changes to the rear tub and bootlid etc.
seems the two guys above, understood
