- My model of MX-5 is: 2011 MK3.5 (NC) 2.0 Sport Tech (Retractable Hard Top), 138,000 miles
- I’m based near: Hertfordshire
- I’m looking for technical help or recommendations on: Emissions too high/intermittent engine light
Hi all, I have a really confusing issue that I am really struggling to sort. The car has been to multiple garages without a concrete diagnosis. Wanting any advice/input from anyone, or to help brainstorm solutions!
The main symptom is MOT emissions - I had an MOT that the car was put through as a pass (but I was informed that the emissions were not pass-able - the car was put through anyway). To my eye/ear/feeling, the car idles rough, and shakes more than it should, and stalls easier that I would like. But I have not had an MX-5 before, so don’t know if it is entirely normal.
I took to a garage, they hooked up tester and confirmed ‘emissions too high.’ They latched on to an old engine light that had come on briefly a couple of months before for a day or so. It was code P2096, which I have looked in to extensively. This has many possible causes, but this particular garage ruled out compression issues, or air leaks. They were convinced the P2096 means the Air Fuel ratio sensor (also known as the first oxygen sensor) needed replacing. Replaced with new aftermarket sensor, same engine light (P2096) now permanently on with new sensor, but interestingly after it drove very well for about 3 or 4 miles. They then determined it needed a genuine Mazda sensor, as the car didn’t like the aftermarket sensor. This didn’t cure problem, and they gave up.
Original air fuel ratio sensor put back in, no more engine light, but emissions still high. I took the car to a well regarded MX-5 specialist, who couldn’t use engine light in diagnosis (testing car as presented, and the historic code had been cleared), but agreed emissions still high: Lambda: fine, Hydrocarbons: slightly high, CO: Near fail. Advice was to drive the car, but monitor oil levels to see if it burns oil.
Again, the P2096 code has been very rare with the original sensors in place (come on twice in 4 months, for a day at a time).
Not expecting an immediate light bulb moment, but any advice would be much appreciated because it is completely spoiling any enjoyment I get out of the car - I don’t want to drive it, and to be honest it’s making me want to give up and get rid.
Thanks in advance!
