I wonder if anyone can help me, I’ve always fancied having an MX-5, and a colleague at work has decided to sell her 1991 Mk1 Eunos 1.6 (Japanese import) it has around 90K miles on the clock.
However, after having looked at the car, the only real problem would appear to be a continuous tapping when the engine is running, from idle through to when being revved, the engine was left to idle for 10 minutes and the noise continued.
I’m suspecting that it may be the hydraulic tappets and as the car hasn’t been used regularly and am guessing the oil has drained from the tappets.
The oil in the sump is relatively new oil, although I’m not sure which grade/weight .
My concern is that the tapping noise should have subsided when the oil had circulated around the engine but after 10 minutes of idling the noise was still present.
Is there any way of understanding if this is a purchase worth pursuing with this problem, should I:
- Leave the engine to idle and see how long it takes for the noise to subside – if so what is a reasonable length of time in which to expect to see the situation improve.
- Take it for a test drive to circulate the oil and see if this helps the issue
- Buy the car as the remedy is relatively inexpensive – what is the remedy?
- Stay well clear as replacing the tappets is a complex/costly job – if so how much should I expect to pay?
Any advise is thankfully received
