Rogerzilla
You appear to disagree with Exxon Mobil the makers of Mobil1 about the base oils they use.
I am no expert but I suggest you read the following, then come back on this one.
Exon Mobil produced the presentation I linked to in I’m informed around 2007 and advised that for 0W/40 New Life they were going over to the VISOM group III+ base stock that was not a POA base oil but that they would add POA additives. Page 28 to 30 refer.
The also said that they would not advise users except in Germany again page 30 refers.
They further advised they would change the base stock to the GTL group III+ base stock in 2010.
I quote from the Exon Mobil presentation
“Visom is the only non-PAO stock that can deliver the required performance to formulate a 0W grade oil that meets European OEM engine oil specifications. Visom is not available to our competition.”
In Germany an oil that is not POA based cannot be called a synthetic oil. It has to be called a HC hydrocracked oil if it is a Group III or the later Group III+.
Go here to the Mobil1 UK site and it sates all the oils are fully synthetic. That term has never been legally challenged in a UK or US court. 0W/40 New Age an excellent non low Ash oil good for cars designed from say 1980 to mid 2005 roughly is called fully synthetic.
http://www.mobil1.co.uk/synthetic-engine-oils.aspx
Now go to the Mobil1 German site and it advises all the Mobil1 oils are SHC Synthetic Technology. So they are referring to them as hydrocracked.
http://www.mobil1.de/produkte/new-life-0w-40.aspx
Further if you use a translator they advise.
Both motor oils are made from crude oil that is pumped from the ground. The difference is that synthetic oils are prepared in a modern refining process and characterized pure and of higher quality than conventional oils. The unique molecular structure allows increased impurities in the refining of the oil to be removed. The oil is pure and can be tailored according to the requirements of modern engines and provide more power reserves.
So if you still want to believe that Mobil1 0W/40 which we both agree is a great oil is still made on a POA base then that is fine but I would say it is misguided.
Have a great weekend
