- My model of MX-5 is: 2005 mk2.5 icon
- I’m based near: Chesterfield
Hi all. This morning I replaced my crank position sensor (gapped using the credit card trick) as I noticed it was cracked when I did my timing belt a few months ago. As I was putting the tools away, I started the car and let it come down to idle to make sure it was alright and gapped correctly.
However, about 30 mins later when I went to do a quick test drive, as I started moving the engine cut out. I thought maybe I’d just stalled it, so I started it again, drove down the road and then it cut out again.
I tried starting it again but this time, it caught and then stalled when I pressed the throttle. I managed to get it started again by:
- Turning to ignition
- Unplugging the MAF
- Starting the car. It was rough and probably not driveable, but it wasn’t cutting out.
- Plugging the MAF back in.
This obviously caused a CEL, but I managed to get home. I though I was in the clear, but when I was straightening up on my drive, it cut out once again. I tried the same trick again and it worked for a shorter duration. Now whenever I start the car it either: a) idles, then stalls when I apply throttle or b) stalls straight away.
I checked the TPS on my code reader and it seems to be accurate.
I made sure everything I unplugged or removed has been re-installed (crank sensor, MAF, Air temp, breather hose).
I’m thinking this is either a MAF or TPS issue, but I wanted to get your guy’s thoughts on it first.
Cheers.
