Entering latitude and longitude coordinates into satnav
  1. My model of MX-5 is: __2025 2.0 ND RF Exclusive Line
  2. I’m based near: __Crewe
  3. I’m looking for technical help or recommendations on: __how to enter destinations as coordinates into the satnav in the new Mazda Connect infotainment system. I can enter the latitude, as it is always set to N, and everywhere I am going to go in this car is in the northern hemisphere. However, when entering longitude, I can only enter positive numbers, either as decimals or in degrees, minutes and seconds but I cannot change the “E” to a “W” as there is no option to do this. So I can only enter longitude values which are east of the Greenwich meridian, which means most of the UK is excluded. Has anyone figured this out please?
If you push the rotary knob up so that the N/S or E/W section is highlighted, and then press the knob in, it toggles each section between N/S or E/W respectively.
