- My model of MX-5 is: __na, eunos
- I’m based near: South yorkshire
- I’m looking for technical help or recommendations on: __question for the officiandoes… When a mx5 leaves the factory is the adjustable suspension points, ie8, set at zero, or is each car set up individually as I havejjust restored my Eunos and done all settings at zero
If you mean a “standard” default factory spec, I do not know for sure but it would make sense and be surprised if not. Cannot see Hiroshima wasting their efforts on wayward errors.
However, if it was mine, I’d take it still and get it Hunter’d.
Hi Scottish fiver, yes, it as been quite difficult to get a answer,… Its going for the mot and wheel alignment set up and see if they make any adjustments!
Not factory “settings” but factory tolerance.
On a NA Eunos Roadster, if there is a “factory setting”, then a S-Special would have a different setting from a S-Special (10mm lower shock seats, slightly shorter springs, modified track rod ends).
Factory recommended alignment
FRONT
Caster +4.43° +/- 0.75
Camber 0.4° +/- 0.75
Toe 1/8" +/- 1/8REAR
Caster not applicable, there is no adjustment possible
Camber -0.72° +/- 0.5
Toe 1/8" +/- 1/8"
See:
https://www.miata.net/garage/align.html
http://www.hummingbirds.net/alignment.html
https://www.miata.net/garage/alignment/index.html
