- My model of MX-5 is: NB
- I’m based near: Portsmouth
- I’m looking for technical help or recommendations on: Strut braces
I’ve just fitted a torsen lsd and noticed a couple of sheared bolts where I can only assume there should be a factory fitted strut brace across the rear subframe.
The front most mounts are where the bolts have been sheared, the rear has a captive nut on one side but just a hole on the other.
Should there be one or two braces? Should I be replacing these? The car gets driven fairly hard.
While on the subject, I’ve not yet checked the front. Should I find any supports there too?
Tom
