Hello folks,
Wasn’t sure where to put this but I’m after some serious advice, I’m not really sure where to start but I’ll try and cover everything that is troubling me with my 1.8l 1994 Eunos Roadster. Firstly I put it in for an early MOT today and it failed on exhaust emissions, below you can see a screenshot of that failure as well as the printout included on the exhaust emissions:
First question is, is this being tested correctly as from what I’ve read it should be tested as an import and have to meet different emissions than a UK car? Secondly, if it is correct then what would be the most likely cause of this in an NA? Cat, Lamba sensor, the aforementioned oil leak? (FYI. My exhaust is also blowing at the Cat but I doubt this would be the cause)
I’m just not wanting to get ripped off here and have to fork out a fortune for something that is an easy fix or even something that hasn’t been tested correctly.
Next is the oil leak, I was initially under the impression that this may be the rocker cover but looking myself it obviously isn’t, there is no oil around the rocker cover, there is oil everywhere else. All over the rear of the engine is oil and looking underneath, the whole underside of the engine is caked in oil. I didn’t realise it was this bad of an issue until actually looking at the amount of oil, according to MOT records, on and off the existence of an oil leak has been present since 2012 but due to it not appearing on all MOTs, I put this down to other minor leaks that have since been repaired.
See the images below for some crap shots of the amount of oil on the engine.
(right click image -> open image in new tab - for full size images)
Now after taking it to one garage, they said it looked like it was coming from a cam sensor, taking it to my main garage, they said the same thing a few weeks ago but when I handed them the keys over for MOT today and asked them to fix the leak, they’ve said after having a better look at it that it could be coming from the cylinder head but if that’s the case then worst case scenario, I’m probably looking at an engine rebuild.
Lastly, on top of the dreaded ticking on start when the engine is cold, I also get a terrible grind at around 2000RPM, sounds like it’s coming from the transmission but it also happens when I push down the clutch, I’m guessing fitting a new clutch kit would be the first thing to do for that?
I realise the images are poor and the information is a bit vague but I’m kind of panicking at how much this is all going to cost and any help would be much appreciated.
I only took the bloody thing in for MOT early to see if any of the rust would cause it to fail so I could get that sorted but it’s come back with a myriad of other problems instead and no mentions of the rusty bits.
Any recommended garages for MX-5/Eunos MOT/servicing/repairs would also be welcomed, I’m in the West Midlands but am happy to travel a reasonable distance.
Thank you in advance, if any more information is required to more successfully answer these questions then please let me know.
John
