I am about to change the final drive oil on my 2018 2l RF . Do I need to use the expensive Mazda long life oil or will a similar spec Halfords oil do the job?
My model of MX-5 is: __2018 2l RF
I’m based near: __Coventry
I’m looking for technical help or recommendations on: __differential oil
Most oil manufacturers have a recommendation page on their web site where you can enter your reg number and they will suggest which of their products to use. Most oil manufacturers either do not make a recommendation for the Mk4 diff, or say something like “refer to technical”. They do make recommendations for other areas of the car so read between the lines.
t might be worth looking on the Castrol website and putting your reg into the system. I’ve recently replaced all the oils in my ND and they even have LSD oil available. Sourced all the oils from Euro Car Parts.
