Ohlins 3 way on rear. Please ignore crude jubilee clip mounting, will make some can mounts later. Fronts to follow.
They look lovely!
Adjustable drop links too? Fresh bushes on the ARB as well? Poly bush?
Thanks goatboy, adjustable drop links, a bit of stainless bar and some second hand M8 rod ends from work. New bushes and clamps on the ARB, lost the originals.
Took ARB off as car was being used for production car trials and wanted the corners to be as independant as possible. When I changed to autosolos the car rolled too much so the ARBs went back on.
Steered away from poly bush at the moment. Quite costly and the rubber bushes last much longer.
Cropduster, body and chassis protected enough. Have spare subframe assy which I am having shot blasted and powder coated.
