I have just finished fitting an double din car play Sony unit in NC and realised I forgot to eject a CD which was in the car. Rather than refit The old unit to get the CD then reinstall the new unit, how can I hot wire the old one so I can eject the CD.
Thanks in advance
My model of MX-5 is: _2006 NC
I’m based near: London
I’m looking for technical help or recommendations on: __
Depends on how confident you are with electrics and if you have some wire and small terminals available. 3 connections should do it if you want the pin locations. I’ve stripped those units down before to recover CDs from units that are broken. Probably easier to go on eBay and just re-buy the CD.
I’m OK with electrics, do have wire, terminals and mini croc clips, so shouldn’t be a problem. I’m assuming permanent, switched live and earth is required.
The CD is a special one off compilation made by a close friend, hence would really like to get it back.
