OK Folks
STOP PRESS from Stuart Stringer - Customer Relations Manager at MAZDA UK
NOBODY FIT OR SUPPLY AN SH01 CODE OIL FILTER TO ANY MX-5
I think admin will need to create a sticky post about this on the Servicing Section - as it looks like all NC models will be affected and there are a lot of dealers and MX5 parts specialists who are either unaware of the technical bulletin - or trying to shift obsolete stock.
The engine reference he refers to e.g. LF is at the start of the engine number in your log book and stamped on the engine - mine is LF1049****
It is also coded into the VIN number e.g. mine is
JMZ (made in Japan)
NC (model reference)
18
F (signifies LF engine)
but please contact your Mazda Dealer if you are in any doubt as to engine type.
Good morning Mr Turner,
Thank you for the original email enquiry and time on the phone just now. I note the request for information on relevant oil filters and am happy to clarify further.
A service information bulletin was introduced in February 2016 stating any time an oil filter is replaced on the below engines, it should now be fitted with LF10-14-302A-9B.
Previous part number – SH01-14-302A
New part number – LF10-14-302A-9B
The above listed LF10 filter is now to be used on all LF, L3, L5 and L8 engines. Where applicable we recommend any servicing is carried out at a Mazda Dealership and would always recommend speaking to a Mazda Parts Department for correct parts if this is not the case…
(NB/ LF10-14-302A-9B is not to be used on SH or S5 engines).
The SH01 filter is still used on other models across the Mazda range, including the Mazda CX-3 and CX-5.
I hope this helps with the original enquiry and if there is anything else I can do to help in the future, please feel free to reply to this email or call me on 03457 484848.
Yours sincerely,
Stuart Stringer
Mazda Motors UK Limited Victory Way | Crossways Business Park | Dartford | DA2 6DT Tel 03457 48 48 48
