Hello All,
Another thing to add to my list of “things to sort out” concerns the alignment and fit of the driver’s side front wing.
The car has had some paintwork done at some point (not sure when, what or why, but I was informed by the seller). I suspect some of it might be for the front wing, as it does not seem to line up as nicely as all the other panels on the car. It is by no means bad, but when viewed from the front it does not line up flush with the drivers door - it seems to be a bit lower than the door at the top curve, and the gap between the bonnet and the wing on that side is fractionally wider on the other side.
It’s not bad, but it is annoying me and I know I will want to sort it as I get the car fully tip-top.
It almost looks as if the wing is a new one, and is not a perfect fit, if that makes sense?
Also, the driver’s door is ever so slightly proud of the rear wing when closed - but this is really minimal, and could be due to hinge and latch wear over the years I guess…so I am not bothered on this one.
Pics
Driver side - you can see how wing is slightly proud of the door - it looks worse here actually due to the flash, and this is the best angle to see it. On a general glance it is not really as bad.
other side, as a comparison…
So, what is the best thing to do to fix this? Coould it in fact be the door that is the “wrong” fit - I think it is the wing due to the fractionally wider bonnet gap though. New better fitting front wing? Body shop fettling the wing I have got?
AS I say, it is not at the top of my list, as overall the car seems (so far) to be very sound (fingers crossed) for what is after all 19 years old.
I would welcome any comments, and even better if someone wants to look at it / meet etc, that would be ace.
cheers
Chris
