frount near side brake disc getting hot
 having just used my Mk1 to go a short distance of 4 miles i felt the car was slowing down quicker than normal. I checked all around and found the frount disc and wheel was a lot hotter than the other 3.
Could the calliper be sticking? if so whats the normal cure for this. Plus what about gaarge costs ish
Thanks  Pete james
 It does sound like a sticking caliper. If i were you i’d take take it apart and clean the slider pins and the shims that the pads move on. Dont forget to regrease.
If its still sticking i’d imagine a new caliper is whats needed.
Had the same recently with the OS front on our Mk3. Attempts at freeing up failed - recon caliper purchased for around £130.
Regards
    Jim
 If the disc is getting hot it will be because the piston is sticking in the caliper. The piston rusts around the seal under the dust seal and causes the piston to drag against the seal so it will not draw back sightly after the brakes have been pressed.
Purchase a new piston and repair kit from the likes of MX5 Parts and strip the caliper and replace the piston, seal and dust seal.
It’s not hard to do and if you purchase the parts any garage mechanic will be able to sort it in under an hour.
Perhaps you should purcase two pistons and two seal kits and have both sides done as I have always found that if one side is sticking then the other side will not be far behind. Save on the garage expense and get both done at the same time.
Let us know how you get on.
A common problem on these cars, I have found cleaning and lubing the pins, and levering the piston into the calliper then applying the brake several times will often free it up, this only works on the front as the rears have a screw adjuster system.
If it persists then a new calliper is the only way, catch it early and you will hopefully save your discs.
Mike
G’day mate Welcome to the forum–
Just signed in for the first of many visits? Please pop your location in your profile, and the year and model of your MX5 in your sig. This helps enormously when we try to answer questions…
Forum Technical Index
