As per subject; does anyone have any hints on how to find this? I gather it’s near the fuses above the accelator pedal but despite nearly putting my back out I can’t seem to find it.
If you remove the fuse box cover then the lower panel to the right of the steering wheel you will be able to see better. The fuel pump relay has four wires, Green/red. White/blue. Black/white. and Black. Sould help you to locate the correct one.
Regards Geoff Peace.
Thanks Geoff,
This is very helpful.
Cheers,
Simon
I am very sorry Simon, I do apologise but I have read the wrong line in my notes and given you the wrong wiring colours for the fuel pump relay. Ignore my previous post. Now the correct information is:- Fuel pump relay, four wires two are White/blue, the third is Red/blue, the fourth is Red/white. Profuse apologies again for that Simon, entirely my fault. Put it down to old age!
Thanks Geoff - no problem; I know the feeling.
Cheers,
Simon
