Fueling Problem - Mazda MX5 1.6 1998
Please help a MX5 owning damsel in distress!
When my car is started from cold, it appears to struggle to feed enough fuel through to keep the engine running. As strange as it may seem, this problem gets much worse if the steering wheel is turned towards full lock on either the left or righthand sides.
I have had some great advice offered, which has resulted in replacing a full set of plugs, leads, fuel filter and a water temperature sensor sited at the rear of the engine, but sadly, all to no avail.
I would welcome any thoughts or suggestions in order to diagnose the problem, or can anybody let me know of an independant garage who have diagnostic facilities available?
Helsmx5
Turning the steering wheel will give the PAS pump some work to do which will put a load on the engine.
It sounds like a cold start enrichment or idle speed problem to me.
Is the problem still there when the engine has warmed up?
Does the idle speed increase when the Air Con is switched on or the blower fan is set to 2 or higher?
I would suggest getting the air valve and the idle speed controller checked over. Also, have the ECU checked for fault codes and if all else fails then have the fuel pressure checked.
The air valve should be the first thing to look at because this only affects the running of the engine when cold. A used air valve costs £25 + VAT from AutoLink.
G’day mate, welcome to the forum
I’m going to move this to the garage section
 Hello Niggle,
Thank you very much for your response to the fueling problem with my much loved MX5.
My mechanic has checked out the idle speed contoller, which appears to be up and running ok, but I will immediately I will pass your comments on and ask that he checks the other items, in an attempt to sort out the problem.
Thanks again.
Helsmx5
I think that the idle speed controller only comes into play when the engine is warm and things like the air con, heater blower and headlamps are switch on. If the idle speed is stable when the engine is warmed up then this component is probably working as it should. The air valve is a separate component that increases the idle speed when starting from cold.
Not sure if your MX5 is one of the early cars with pop-up headlights (Mk1) or the Mk2 with fixed headlights. The Mk1 has two water temperature sensors, one for the ECU and one to drive the temperature gauge. The sensor for the ECU is the one that will affect cold starting and running and is the one that should have been replaced if necessary. On the Mk2 a single sensor with two separate terminals drives both the ECU and the temp gauge.
Mk1? Sounds like the base idle needs resetting.
Paperclip in the DIAGNOSIS box to bridge GND and TEN
With engine running adjust the screw on the throttle body until the idle is at about 850 rpm on the rev counter in the dash.
remove the paperclip and adjust the screw again so it is at 850rpm, replace the paperclip and it should stay the same, if not adjust as required.
If the base idle is set too low it will under fuel.
Mine has a bit of a similar problem i think (mk1 1.6 1992) it idles really pretty poorly when cold, sounds quite laboured when i switch on the blower and lights. yet ive set the base idle (when warm i take it?) and it idles smoothly when warm it does drop a little bit if i load it up?
Thanks again for your valuable ideas, I’ll try the air valve and fingers crossed that it solves the issues. Many thanks.
Thanks for taking time to respond. I will pass your comments on to my mechanic and give it a go.
Ps. Alnick is such a great place to live!!
Do you live close? If so, bring it round and save on the mechanic bills. I’ll adjust it for nowt.
Thank you, but I live in Ilkley. Have spent many a happy hour wandering around the castle and then into The Victoria to warm up!!
