I should apologise for this, but anyway, here goes. FULL BEAM, FOG lights, why are so many drivers using these lights incorrectly? I drive for a living (over 3 million miles now) and years ago, if someone forgot to turn full beam off, a quick flash to remind them and they immediately turned it off. Very few people used fog lights, unless it was very poor visabillity. Now it quite common for drivers to leave full beam on (intentially) or only dip them after continuous flashing from other drivers. Fog lights seems like every other driver has them on and rear fogs when it’s raining in the dark, (wtaa) or in mist with visibility well over a 100m. Then you get those that drive on full beam and fog lights.
Not only is it any offence to drive with fog lights on when visibility is above 100m, dazzling other road user with full beam is too, so these new full beam assist lights that only dip when it’s too late (brow of hills, clear line of sight corners where the oncoming car can be seen, long before the full beam is dipped etc and then, also it’s only dipped after about a second of full led/xenon blindness). Last year, I sat in a traffic jam on the M40, 4 lanes of very slow and stationary traffic, in the dark, good visibility, and every other car, had rear fog lights on, as well as rear brake lights
In a truck, it’s even worse, because you not only are looking way ahead, round corners etc, (we all should be doing that anyway) but, because your so much higher, you see over hedges, concrete central reservation, brow of hills etc and when it’s raining in the dark, a lot more glare from full beam and fog lights reflecting in the mirror like dark wet road surface. last night after a 405 mile journey, I counted 47 cars (yes, it gets boring driving on the motorways, so you have to entertain yourself), who were driving with full beam (and didnt dip them). About a dozen also had front fog lights on as well and probably the same had rear fogs on (it was raining, but good visibility).
ofcourse, the new problem, is the adaptive full beam (volvos, Range Rover and mercs seem to be the worst) the drivers are told, that they can leave full beam on and the led headlights will adjust according to what’s in front, thereby not dazzling other road users, well they don’t! Anyone is welcome to sit in my truck whilst someone with these lights is either coming towards or from behind (4 very large rear view mirrors to be blind by) and will understand what I’m having a rant about, they are apita, or should that be eyes. Yes, there great for the driver, he or she can see for miles, but there not for anyone else.
All these modern feature are great, but there not perfect and drivers need to understand that and use them accordingly (full beam assist is for lazy people) if you see light ahead, even if you cannot see the headlights, you dip your full beam, because you know another vehicle is about to appear, and its too late to dip them once the lights are visible, you’ve already dazzled that driver. You also dip them early so your eyes can adapt to a lower light level. Fog lights, they do very little illumination of the front of a vehicle, but cause a lot of glare and rear fog lights, the switch in the car should have a very bright red light, to remind drivers it’s on, then they might only use it when really necessary and switch it off when not needed. Now I know your average mx5 driver is probably a much better driver, as their more interested in driving well, improving their skills and enjoy driving, but how far dose the average driver look ahead and actually think about what there doing, it would appear that some, about one car length, if that.
I’ll get down off my soap box now, sorry for the rant.
