What are most people paying for a four wheel alignment with adjustment ?? Just out of interest !!
WIM has charged me seemingly random sums each time I have visited; around about £90-100, though last time I was there, after 5Speed couldn’t sort out a run-out problem with one of my wheels, they charged me about £100 for 45 minutes of fiddling around, with seemingly a before/after print out of all 4 wheels (which sounds to me like an alignment check and adjustment), and then some lackey tried to offer me an additional “bargain” alignment check/adjustment on the same day for “only” £75. I’ve since found out my local Alfa specialist, with the same grade of kit, and experience in setting up race cars, can set the car up for £60 (and the owner’s other car is a MX5…). £100 seems to be about average; though Northampton Motorsport could supposedly do “alignment for life” for £200.
I paid a little under £60 at Chemix, in Halesowen, last Spring. Seemed to do a good job, it did make a difference.
Hi
Got mine done at Exchange Tyres Middlesborough after fitting the lower springs to my mk3, no adjustments necessary so only £25 - great
Bob
Supertyres in Maldon give free alignment checks to OC members and then charge only for the angles they adjust. Full alignment with OC discount is normally around £50.00.
http://www.super-tyres.co.uk/
i do my own joys of working as an alignment tech .
the company i work for charges the following
front toe £25
rear toe £20
cambers £15
caster £15
when you get mx5’s in, do they all need the caster adjusting? i have tried to measure mine, but i’m not sure how to get an accurate measurement. i was going to leave it for now just to see how it was
i have been quoted up to £70, depending on how much needs adjusting. However, as all 4 of my wheels were pointing in different directions, i have nothing to lose, i am trying to set it up myself. Its a good way to understand how it all works for a novice mx5 owner. if i cock it up, then i’m going to fork out the £70.
I went to WIM on Monday and it cost £95 plus VAT £114 in total.
1st visit to WIM Aug 08 26kmiles,lots of adjustment=£85
2nd Sept09 37kmiles,check up and small adjustments=£40
3rd Mar11 48kmiles,check up and small adjustments=£51
All ex vat.
First time change was amazing,felt a completely different car,also had 4 new tyres at first and 3rd visit.2nd visit due to a perceived problem(bump steer)turned out to be a broken drop link.
Went to E.Grinstead WIM contact and same as Andy £114 - a great improvement .
Steve
Who did you use in East Grinstead?
STS Tyre Pros - very friendly and the coffee`s good too !
sets cars up for motor sport doing the alignment and someone who fits tyers for
a living doing it?
