Took my car to HiQ today for an alignment. I should have bailed out when I handed the “technician” the settings I wanted and he said “Can you adjust the caster on these?”. After 20 mins he said “All done”. I looked at the printout. No camber/caster adjustments made, just toe in. “You don’t adjust the camber, because it’s greyed out on the screen, so it’s right”. Same story from the man on the desk. Eventually another guy came, took another hour and a half and got it set up, so he really didn’t have a clue about setting it in the correct sequence.
Handles wonderfully now though, thanks to the settings provided by Tony at WIM (THANKS).
I asked him for settings for safe predictable road use, ride height 320 front, 330 rear.
He suggested :-
Rear Camber -1 degree 50min, Toe in +20 min per side
Front Camber -50 min Toe in +8min per side Caster +5 deg 30 min
