Like them all. Can’t make my mind up whether I prefer the ones that stop at the back of the door or the ones that carry on to the rear arch. Certainly all in the right spot, doesn’t detract from the lines of the car, if anything breaks up the slightly slab sided look of the car. Don’t shoot me down in flames on that one, remember the Mk1 had an indentation running front to back and the Mk2 a large bulge along the bottom of the door. Mk3 door has less detailing hence my use of the ‘slab sided’ term.
Really does need a GT badge on the boot to gain the highest performance boost though. Personally I’m still struggling to get the beaded seat covers to fit properly over the side bolsters.
Personally bought mine off eBay from this seller “loobyloococo”, price over 1yr ago £23.99.
There is a bit of an art to fitting them, but plenty of youtube instruction vids for putting on stripes.
Having now seen other peoples I would probably have gone with the ones that stop at the door as the gap between the sill cover and rear wing it as an angle and was a bit tricky getting this lined up.
I have had no problems with the stripes ,they have not lifted at the edges, and my car gets washed a lot with a power washer and is left outdoors all year round.
i’m a dunce and I fitted mine … masking tape the spies to the car before fitting to get the lines. Spray the bodywork (which you have already washed naturally) with a mild solution of soapy water apply stripes. Squeeze out air bubble and let dry… when dry slice gaps with sharp blade.
