- My model of MX-5 is: 2017 ND RF
- I’m based near: Manchester
- I’m looking for technical help or recommendations on: Electrical Funz!
Hello, I have been having some “fun” lately with an intermittent problem on my ND and was hoping someone might be able to provide some advice.
I believe original symptom I encountered was the boot opens when starting the car. When this occurred I had not been in the boot before starting the car and the key was in the center cubby so the button wasn’t pressed.
Sounds like the opposite of this: Mx5 ND, Boot opens when turning off engine (Edit)
I have since had more developments which are a little more worrying, namely 4 symptoms that occur together:
- Boot buttons don’t work
- Boot release button doesn’t work
- Fob button doesn’t work
- Commonly literally just after I have closed the boot and realize I need something
- Sounds like this: ND RF External Boot Release Button Not Working
- Interior (dome) light doesn’t respond to doors/turning the car off
- The light can be turned on using the switch so the bulb is fine
- Washer doesn’t work
- Wipers are fine
- Washer bottle is brimmed
- Fuse is fine
- High Beam doesn’t work
- Dash displays indicator
- Fuses are fine
The really annoying part is that it is intermittent and sometimes just works!! So I know that everything works but at some point during a drive they will just stop functioning and even when I stop > car off > car on, it doesn’t always fix it.
Recent scenario: Opened boot, deposited items, closed boot, started car, back to boot (forgot something), couldn’t get in, drove to Tesco, still can’t get in, test washer, doesn’t work, back from Tesco, check fuses, fine, notice interior light doesn’t work, drive ~45 mins, washers still don’t work, boot works on arrival as do washers and interior light.
Few hours later, test everything, all good, drive for 10 minutes, high-beam dies, washer no longer works, interior light has gone too, finish 45 minutes drive, tinker until everything works (wiggle interior fuse box, check fuses etc. all good) and I can finally access boot.
I have looked and believe they are all linked to the ESU but that seems fine and when everything works it all just works!
Haven’t had a chance to get a decent code reader plugged in to see if there are any errors.
I have fully disconnected and then reconnected the battery, it behaved for a bit upon reconnection and starting but when the car was next started to was all kaput again.
Hopefully someone has some thoughts as I am starting to pull my hair out over this as it is so frustrating and infuriating ![]()
Might be worthing noting…I have previously fired my main fuse which also killed the washer fuse (but after replacing it was fine for a good few months) and I have been caught in torrential rain with the roof down but I tried to do my best in drying everything out thoroughly
