Guide to fitting an auto dimming rear view mirror & glove box light
 Hi & I hope that this is in the right forum (if not my excuse is that this is my first posting!)
Having just fitted an autodimming rear view mirror & glove box light to my 59 plate MX-5 Roadster Coupe - I realise that there wasn’t a comprehensive guide on how to do this on the web, so have created such a guide, in the hope that it’s of value to someone else.
All the work was done with roof down for ease of access. Total time taken about 3 hours.
1.       Remove original mirror
a.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>It appears that this is held on by springs either side of the mount – see image of original mirror base mount  below:
b.    Push up from below, using a flat blade screw driver to release catch. This is a fiddle and gently forceful side to side wiggle seemed to help!
2.       The windscreen mount thus looks like:
3.       Remove the windscreen header trim torx screws – one under the sun visor, two under the roof alignment piece on the left hand side only.
4.       Remove the A pillar trim – this pulls out towards the centre of the car, held on by clips.
5.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>Pull down on the windscreen header trim at the left end – it will flex in the middle – and is held in place by clips. No need to remove right hand side.
6.       Remove the door seal trim on the left side.
7.       Remove the fuse cover and then remove the fuse panel itself – there are two clips, one black one at the bottom of this piece and a white one under the cover. Removing the sill cover aids here – this pulls upward to unclip. The fuse panel removes by pulling towards the centre of the car.
8.       I found it easier to remove the glove box at this point. Undo the tie on the left side connecting the glove box to the damper (white tubular piece) but retain it with a length of wire. Press both sides inwards to release and the glove box will release when dropped down.
9.       Fit the new auto dimming rear view mirror - a Gentex Genk2 – to the windscreen mount. This fits over the original mount with no modification. Tighten the torx screw on the base mounting to secure when doing the final reassembly.
10.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>Plug the cable socket into the mirror. The cable can be taped to the mirror arm. A cable cover from the mount to the header can be purchased separately (not used here as the cable can’t be seen from the outside). Run the cable up into the windscreen header (there is a convenient cut out in the middle) and run along the original cable bundle.
11.  Run the cable down the original cable bundle in the A pillar using cable ties & tape to secure.
12.       Drop the cable down to the fuse box.
13.       Wire the mirror cable to the fuse box. I used the accessory fuse which is the second one down from the top in the top block. The top block of fuses can be removed by sliding the black block forwards on the white mount. This makes it much easier to access the cable at the back. The positive supply cable is the yellow cable to the second fuse from the top. Clear away the black cable tape to expose.
14.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>Apply the supplied red T-Tap connector to this yellow cable.
15.       For the negative ground I used the bolt holding the fan assembly.
16.       Connect the red spade connector to the red T-Tap connector and the blue ring connector to the bolt (10mm spanner/socket).
17.       Test the mirror is functioning by turning the ignition switch & check that the green LED to the left of the mirror power switch illuminates.
18.       As the glove box area was exposed I decided to fit a glove box light at this point. If this is not required then ignore the next bit & replace everything!
19.       The light source was a 5 bulb LED block.
20.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>This was fitted up behind the locking mechanism using double sided tape.
21.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>A small push to break switch (Maplin FH60Q)was fitted to the top left side of the glove box opening so that the rubber plug on the top left corner of the glove box would activate it on closure.
22.       Solder the positive lead from the LED block to the switch (before fitting!) and add sufficient cable to reach down to the fuse box.
23.       Fit a spade end to the positive wire and a ring end to the negative wire.
24.    Use the spare blue T-Tap connector from the mirror kit & fit next to the red T-Tap connector on the yellow cable. Fit the spade connector on the positive wire to this T-Tap connector.
25.       Connect the ring end on the negative wire to the bolt as used for the mirror negative wire.
26.       Check the LED bulbs are lit, confirm the switch turns them off when pressed.
27.       Replace the fuse block on its mount & tidy away the cables.
27.       Replace the fuse panel & cover. Replace the sill trim, and door seal trim.
28.       Replace the A pillar trim.
29.       Replace the windscreen header trim – this will need firm upward pressure to replace the clips.
30.       Replace & tighten the torx screw under the visor. Replace the roof alignment piece and the two torx screws – leave loose at this point.
31.       Close the roof, ensure a correct fit with the roof alignment piece then tighten the two torx screws.
32.       Replace the glove box – the reverse of removal. Use the wire to retrieve the damper cord & refit to the fixing on the left side of the glove box.
33.       <v:shapetype coordsize=“21600,21600” o:spt=“75” o:preferrelative=“t” path=“m@4@5l@4@11@9@11@9@5xe” filled=“f” stroked=“f” id="_x0000_t75"><v:stroke joinstyle=“miter”></v:stroke><v:formulas><v:f eqn=“if lineDrawn pixelLineWidth 0”></v:f><v:f eqn=“sum @0 1 0”></v:f><v:f eqn=“sum 0 0 @1”></v:f><v:f eqn=“prod @2 1 2”></v:f><v:f eqn=“prod @3 21600 pixelWidth”></v:f><v:f eqn=“prod @3 21600 pixelHeight”></v:f><v:f eqn=“sum @0 0 1”></v:f><v:f eqn=“prod @6 1 2”></v:f><v:f eqn=“prod @7 21600 pixelWidth”></v:f><v:f eqn=“sum @8 21600 0”></v:f><v:f eqn=“prod @7 21600 pixelHeight”></v:f><v:f eqn=“sum @10 21600 0”></v:f></v:formulas><v:path o:extrusionok=“f” gradientshapeok=“t” o:connecttype=“rect”></v:path><o:lock v:ext=“edit” aspectratio=“t”></o:lock></v:shapetype>Finished mirror!
It is marginally larger (by the size of the surround) than the original. However when correctly angled neither visor catches it.
Much better than getting blinded then having to manually change the mirror (then forget to change it back & wonder why I can’t see!)
 I like this,and just ordered two,thanks very much for your time and info.
But where did you get the LED block from???(sorry if you have said)
Regards
Hi. You’re welcome - would have saved myself at least an hour if I’d known this in advance.
The light block was sourced form:
http://www.virtualvillage.co.uk/12v-pod-light-with-5-white-leds-for-car-and-van-dashboards-002511-094.html
I also bought two of the orange ones as footwell lights, wired to the ignition switch LED.
i cud do with one of those for my mk1 :slight_smile:
 Hi Docrob,
I realise some time has passed since you posted this guide, which is very helpful. Could you provide a similar ‘idiot proof’ guide to fitting the footwell lights to the ignition LED? Wire colours etc? There are other posts on the forum which cover wiring to the interior light, (when doors are opened etc) however I would prefer to have them as running lights.
Thanks.
Hi & thanks for the enquiry.
I wired my foot well lights to the doors open switch at the
ignition (if I remember correctly) so they go on & off with
the interior light. I’m not entirely sure where you’d find a
switched positive feed from, other than that mentioned in fitting
the auto dimming rear mirror.
Side lights inside??? <o:p></o:p>
Dead easy, just tap into and take the live feed from the illumination off a switch, dial cluster bulbs or heater panel bulbs.<o:p></o:p>
But I do need to ask the question…why???
M-m<o:p></o:p>
1. Because it’d look cool (the reason for so many mods, surely). I was planning on red LEDs, my brother has similar in his R32 (some may not like that comparison I feel).
2. I thought it might be more simple than running wires to, and soldering on to, the interior light. But on reflection, could I just wire straight to the ‘+ Accessory’ (yellow wire, above)? They would be on all the time though right? Ideally I would like for them to be on with the exterior lights and also with the doors open.
Cheers for humouring me on this one. I was also thinking of adding a variable intermitted wiper stalk, which may serve a more practical purpose, as part of ‘winter improvements’ before the end of the ‘summer’. I see there is a thread for this, excellent!
 You could just do what most others do including myself and fit a timer delay on to the interior light system(dead easy) which will stay lit for 30 sec’s and fade out. and then also fit your LED’s to the interior light in your footwells etc, which i have done also ,one Roadster lights green, one is red and the other is blue, looks great,is not lit up all the time to cast a shadow on my chins, happy days.
If you want any more info catch me on mazdamenders.net, might even do some pic’s and a write up on it now.
M-m
I’ve pulled power for footwell LEDs from the led that illuminates the ignition. These illuminate when the car is zapped from the remote rather than opening the door.
Hi I know this thread is quite old now, but one thing I really missed when I got the MX5 was an auto dim mirror, however I was a bit reluctant to spend £70 on a new Gentex mirror, looking at the Gentex website I noted that the mirror that fits the MX5 also fits Fords, so a bit of reverse thinking and the fact that my 2003 Mk3 mondeo had an auto dim mirror and I started to search E-Bay, well £15 later I had a Mondeo mirror on its way.  Fitted it today and it fits perfectly! Even wired in to the reversing light so when in reverse the mirror un-dims, so if you want this mod a bit cheaper then search out a Ford mirror.  NOTE it has to be pre face lift Mk 3 modeo as the later ones they changed the mirror fitting, apparently some focus and fiestas had the same mirror but can’t confirm that.  if you can get the connector and a bit of the harness too it helps wiring it up.
Thread resurrection. Just followed this guide to put a gentek 2 mirror into my 2018 sport black rf. only advice would be to mark around the side of the roof striker plate with masking tape so you replace it in the same position. I used a fuse tap into a vacant fuse slot which becomes live with ignition on. Whole job took 90 minutes from start to finish. Don’t understand why car didn’t come with dimming mirror, but not complaining at £70 and factory fit look. Result!
Why can’t I see the images in this post? I’ve tried three different browsers, to no avail. Can anyone advise please?
Because the original poster is no longer supporting them
They are old Photobucket pics, they blocked viewing content a while back unless the poster subscribed. It was free at the time to link from one of their accounts.
