Hardtop wall hanging bars query...
We recently bought, and picked up a hardtop for our Mk2.5 the other week, and it came with wall mounting bars (but no brackets for the wall). I’ve got a beam that runs across my garage that I can hang it on (as well as a the wall if I could find some brackets.). Though I have a query, or rather a problem that I’ve found…
When I fasten the bars to the hardtop, the brackets don’t line up straight…
The brackets are clamped on properly, as there’s only one way will fit…
I assume the brackets would line up straight? They should be right, as they came with the hardtop. Can anyone offer any help etc on if I’m missing something obvious?
Thanks.
Hi Rhys
They don’t look square in this photo…
https://www.ebay.co.uk/p/Mazda-Mx5-Mx-5-Hardtop-Hanging-Bars-and-Brackets/1713800067
You should have a couple of brackets as well that fit to the wall with two bolts on each.
Google ‘mx5 hardtop wall brackets instructions’ and check out  the images.
I have a stand for mine but just a thought, are they handed?
I thought that, but they have bits that enable the side brackets on the hood to clamp onto them, so they only go on one way.
I saw that pic/link when I googled it earlier.
I may just end up buying a stand for it tbh, just thought it strange that they aren’t straight.
Presumably the missing brackets are still bolted to the sellers garage wall. Is it worth contacting them regards
brackets and how it all fits together. Stands tend to be a tad expensive and on eBay always at the other end of the country I found.
Good luck.
I think the hanging kit is a Finishline MCAF588 for MX5 MK1, MK2 and MK2.5.
Here are the missing brackets…
https://www.ebay.co.uk/itm/MAZDA-MX5-FACTORY-HARDTOP-WALL-BRACKET-ATTACHMENTS/253340660068?epid=17012337455&hash=item3afc47b164:g:ZEAAAOSwxixaSqnb
Might be worth contacting the seller for general fitting advice if you are going to buy his brackets.
The little “fingers” that hook into the deck plate locks are slotted, are they both in the same position on the main brackets?
Cheers for that, just bought them. Got 'em for a tenner, which might be a lot for a pair of brackets that I could make, but saves me time and the hood is worth more than a tenner to worry about saving a few quid.
I assume so as everything lines up, as in the side clamps lock onto the bars so the ‘little finger’ things can only be in one place to fit the franken-slots on the hood if you see what I mean.
hardtop hung up
This (image pinched from fleabay) is the hood we bought, and it appears to be hung up on a beam as I was going to do. I’ve decided it should be up against the wall now so it’s out of the way.
It appears to be hanging fine tbh, but the brackets could still be out of alignment.
