Have a Mk1 with brake fluid leaking from the Reservoir.
The fluid is seeping from the seal between the bottom of the Reservoir and the face of the master cylinder.
Is it possible to take off the Reservoir and replace the seals??
If so could any body give any advice ???
Much appreciated
Hi Mike,
The reservoir should be held by a single cross head screw, outside at the bottom. Remove the screw and pull out the reservoir to change the rubber seals. If there is access to the screw this should be possible whilst fitted to the car after removing the fluid with a turkey baster.
Thanks Robert, that’s great
