Hi there, I’m a new member so, apologies in advance if I contravene any protocols.
Despite owning my Mk1 / Eunos import for some time, I am in real need of some help, perhaps surprisingly, to identify precisely what model I have.
About all I can be reasonably sure of is that it’s either a J limited or J2 limited edition.
Although faded in some places, most of the sticker near the door striker bears out that it is a J2 Limited edition. Indeed, this is actually quoted under ‘Grade’ on the sticker. It also quotes the correct HZ paintcode for Sunburst Yellow; CE04D16 engine code, denoting an 1800cc engine; and 5MT under the ‘Transmission’ legend, which I assume corresponds to the car’s 5 speed manual transmission. It also has the black windscreen surround indicative of a J2 Iimited edition.
Interestingly, there is merely a dash under the ‘A/C’ legend on the sticker, although the car does have air conditioning. It also has a CD player and stainless steel kick plates, which I believe were options on the J2.
However, probably the most significant query is regarding the VIN number quoted on the driver’s door sticker, which certainly does not follow the international standard 17 character format. It clearly states an11 character code in the following format: NA8C – 107xxx. Likewise, the same number is stamped on the engine bay bulkhead, where the standard 17 character VIN would normally appear.
A red coloured ‘dymo’ tape sticker on the A pillar at door level simply states: ‘7 7 60700’.
Apart from the VIN issue, the other surprise is that the car is equipped with the 7 spoke wheels that are typical of the earlier J Limited edition.
So, my queries seem to boil down to: ‘Why would the car be fitted with the earlier style wheels, unless these were changed by a previous owner – even though I understand all 800 of the J2 limited run were sold out on the first day of release?’
Secondly, and more significantly, why does the vehicle NOT carry a standard 17 character VIN number. One thought is that the car is possibly a pre-production J2 Limited edition, which just happened to be fitted with the earlier style wheels (possibly as a disguise), while the model undertook road testing / proving mileage prior to the manufacture of the 800 cars for the ‘J2 limited’ model’s run.
Clearly, any assistance would be most welcome in helping me to resolve the mystery.
Thanks in advance.
