OK, so after fiddling around with a
multimeter this evening, I have some success (or at least it appears that way!)
<o:p> </o:p>
First off, the pin layout:
<o:p> </o:p>
1 _ _ _ _ 2<o:p></o:p>
3 4 5 6 7 8<o:p></o:p>
<o:p> </o:p>
These correspond to the following Mk2.5
wire colours: <o:p></o:p>
Grey/Red
Red/Black
Green/Yellow
Black
Blue
Yellow/Red
Black
Unused
Numbers 1 and 2 are obvious: these wire
colours are the illumination for the switch, as with all other switches. These
are tested and these work, lighting up a nice shade of orange. The remaining
five pins must be for the following functions: Earth, front fog, rear fog, 12v.
Being as how there are only four, there must be two earth or two 12v, or
something I am completely missing
<o:p> </o:p>
Next, I tackled the pins with a multimeter.
When the light-up switch is ‘off’, there is a permanent connection
between pins 3 and 4 with a slight resistance between them. There are no other
connections. When this switch is ‘on’, there remains this connection, and there
is also now a connection between pins 3 and 5 (similar resistance) and pins 4
and 5 (no resistance). So this must be the switch and its ‘on’ light.
<o:p> </o:p>
Thinking about this logically, the pins
between the ‘on’ light must create a resistance due to lighting the diode, with
the 12v straight to the fog relay having no resistance. Also, as pin 5 has no
connection when ‘off’, this can only be 12v. Since 4 - 5 is the only connection
with zero resistance, pin 4 must be out to the fog relay. This means 3 must be
earth.
<o:p> </o:p>
So, we now have:
<o:p> </o:p>
Grey/Red: illumination
Red/Black: illumination
Green/Yellow: Earth
Black: front fog
Blue: 12v
Connected up, this works, although I did
first think I might have this wrong and presumed that black must be earth -
this caused smoke to come out of the switch. Still seems to work,
though!
<o:p> </o:p>
Next, I took a look at the other pins… 6
and 7. When the rear fog switch is held in (otherwise it springs back out)
there is a connection between pin 6 and 7. This would mean that these two could
be 12v and rear fog. So this would be:
<o:p> </o:p>
6. Yellow/Red:
12v
7. Black: Rear
fog
<o:p> </o:p>
So, when all this was wired up… it
worked! Assuming this wiring is correct (and I am NOT
guaranteeing it is and won’t melt and burn your car down!), the front fogs
are fine; all that remains is to make the second switch work with the rear fogs
and light the foglight light in the instrument cluster.
<o:p> </o:p>
The rear fog switch on a Mk2.0 is different
to this switch… it rocks left and right, as indicated by Mark above, so
splicing the wires in this switch to the wires from your current switch will
not work as the relay must be different - momentary current down one
wire for ‘on’ and down the other wire for ‘off’ on the Mk2.0 as opposed to a
momentary current down the same wire for ‘on’ and then another down the same
wire for ‘off’ on the 2.5.
<o:p> </o:p>
Now this is where I am out of my depth.
According to Wikipedia, latching relays should solve this problem (http://en.wikipedia.org/wiki/Relay#Latching_relay):
<o:p> </o:p>
A latching relay has two relaxed states (bistable).
These are also called ‘keep’ or ‘stay’ relays. When the current is switched
off, the relay remains in its last state. This is achieved with a solenoid operating a
ratchet and cam mechanism, or by having two opposing coils with an over-center
spring or permanent magnet to hold the armature and contacts in position while
the coil is relaxed, or with a remnant core. In the ratchet and cam example,
the first pulse to the coil turns the relay on and the second pulse turns it
off. In the two coil example, a pulse to one coil turns the relay on and a
pulse to the opposite coil turns the relay off. This type of relay has the
advantage that it consumes power only for an instant, while it is being
switched, and it retains its last setting across a power outage.<o:p></o:p>
<o:p> </o:p>
So, it would seem that this type of switch
would need a ‘ratchet and cam’, single coil relay. I have no idea what the
wiring for this looks like and can’t seem to find this online. I am
guessing it would have an input - this would be the rear fog wire -
and an output for this (these two would activate the coil), it would
then also need a 12v for the coil and an output which would continue to the
rear fog. This output would split and head to the instrument cluster also to
activate the foglight light.
<o:p> </o:p>
Does anyone have any experience here and be
able to offer some help?
<o:p> </o:p>
Thanks,
<o:p> </o:p>
Gareth
