You won’t find a guide as fitting them to a Mk1, or any other Mk retrospectively is illegal. This is a link to the relevant document https://www.gov.uk/government/publications/vehicle-safety-standards-information-sheets General requirements In the Department for Transport’s (DfT) view it is not legal to sell or use after market HID lighting kits, for converting conventional Halogen headlamps to HID Xenon. If a customer wants to convert his vehicle to Xenon HID he must purchase completely new Xenon HID headlamps. The reason for this is that the existing lens and reflector are designed around a Halogen filament bulb, working to very precise tolerances. If one places a HID “burner” (bulb) in the headlamp, the beam pattern will not be correct, there will be glare in some places and not enough light in other places within the beam pattern. The following is the legal rationale: The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK. Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law. However new vehicles have HID headlamps. This is because they comply with European type approval regulations. The UK cannot refuse to register a vehicle with a European type approval. These approvals relate to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (lighting installation on the vehicle). For the aftermarket, a used vehicle cannot obtain type approval because this only applies to new vehicles. However DfT does not think it reasonable simply to ban HID in the aftermarket. Instead the Department makes analogies with new vehicles. It seems reasonable to require HID in the aftermarket to meet the same safety standards as those for new vehicles. The same level of safety should apply. Therefore a HID headlamp unit sold in the aftermarket should: 1. be type approved to ECE Regulation 98 as a component; 2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place); and 3. comply with RVLR as far as “use” is concerned. In practice this means: 1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be “e-marked” to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. - who must test the headlamp in an independent laboratory. 2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have “self-levelling suspension” and that is adequate). Also the dipped beam must stay on with the main beam. 3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly in the same way as any other headlamp. Under the Road Traffic Act 1988 it is an offence to supply, fit or use vehicle parts which are not legal. In summary: it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
