Awfully sorry, but I am unable to provide a photo, so I have to try to explain! With the engine block stripped bare and upended, there is a hole in the internal casting beneath #4 cylinder. It’s about 4cm long by 1cm wide and runs parallel to the internal main oil gallery. None of the other 3 cylinders have this. Is this normal or have I a damaged engine block? Many thanks, in anticipation.
