Anyone done it?
Trying to find some pics how they would look, they are made by Enkei.
64mm Center Bore
5x114.3
ET45 so 10mm difference
Always like the design.
Anyone done it?
64mm Center Bore
5x114.3
What would you do about the smaller centre bore machine shop?
These would do it.
Nc is 67.1?
Oooops! Senior moment from me! I ought to know, i own one! Anyway, moving on!
Yes NC is 67.1 .
I run 7.5 width with 42 mm offset on mine without any problems ,no rubbing .
I have OEM 17" wheels with 25mm spacers all round, effectively making the offset 30mm. No issues with clearance/rubbing and that with lowered Meister suspension. I realise this is slightly off piste from the original question but proves that lesser offsets aren’t necessarily an issue.
That’s a shame I thought the NC was the same as the NB center bore but should have guessed better as NB is 4 bolt hub and NC 5.
Evo 8 wheels maybe then.
I have the standard sport alloys, fully refurbed, they even trued up the alloys when they did them but was looking at OEM 114.3s as they can be bought for little money and the quality is good.
Hi Barrie yes no problems with mine either . I think it only starts to become a problem when you go to very wide wheels and low offsets .
It becomes a problem with 7.5" width with 215 tyres at below 40 offset.
The Jan 2022 picture in the club calendar is 45 offset on 7.5"
