1 Remove Gear Knob (unscrew)
2 Remove center console (5 screws two either side at the front, two in the center arm rest cubby and one under the ashtray*), once the screws are removed the centre console can be lifted from the front end so you can carefully un-plug ashtray light and electric window cables if you have them.
3 Unscrew screw at the bottom of the centre dash unit. (NB has 2 screws)
4 On NB the surround can now be un-clipped from the dash. (NA owners continue to step 5)
5 Remove both eye ball vents (use a screw driver or similar to lever carefully)
6 Unscrew 2 screws at the top of where the eyeball vents were.
7 The center dash unit is now free from the rest of the dash, carefully unplug the pop-up/warning flasher wires and the stereo wires (if you can remove the stereo before doing any of these steps it makes it easier).
8 Remove the pop-up/warning flasher buttons and transfer over to the new center dash.
*You need to remove the window switches on an NB F/L (MK2.5). NB’s have the screw under the ashtray.
