The club Spring rally is at Wentworth Woodhouse in South Yorkshire 24th April, pop along and see a load of fives.
I will be there with my Mk1 on the MazdaMenders.net stand or the competitions, if at all possible I will be more than happy to take you for a spin out.
Iām sure that the OEM stuff was extremely well designed, everything else on the car (rust traps excepted) seems to have been massively over-engineered for what in effect was a cheap sports car, so Iāve no reason to doubt that, though having said that 24 year old shocks no matter how well designed donāt exactly give you an idea of what they were like new. When I had the original suspension on the car the body roll was horrendous, so I suppose I want something compliant, with less body roll than stock.
The lowering springs I have fitted reduced body roll significantly, but the damping is now totally out of whack, so I want a ride that gives confidence on bumpy roads, with less body roll than stock, but better damping and a ride height drop of around 30mm, similar to the performance springs I have fitted.
Iām not under any illusions that the car will never be a rolls, Iām only 30 so I can handle a stiffer ride no problems, but there is that compromise between what works at the track and what works on the roads and I see no point in setting my car up with suspension thatās better for track than road use just for kudos. All three suspensionās mentioned could fit the bill Iām sure, itās just which offers the best compromise and value for money as far as Iām concerned.
[/quote]
Ā
Thanks Speedy! Iāll head down that way on the 24th then!Ā Ā
Just waiting to hand over my sensible car next weekend to a new owner so I can move my 5 up and start enjoying the summertime with the hood down!Ā
I realise the topic of which suspension set-up is very subjective: everyone who drives any given car will feel something different from that car.
Given that proviso, from the perspective of wanting the compliant but controlled suspension for a car intended to be used as a grand tourer, would you say its better to go back to OEM Mazda shocks and springs, or, say, Geoffās Konis and springs. And in that case, which shocks and which springsā¦?
If you want lower and stiffer so as to roll less it will depend on where on the scale of comfort you expect to be. Lower and stiffer does not equate to speed on back roads well.Ā
It is my experience that most dampers work until they donāt. Saying a damper has done X number of miles or Y years old does not mean it has worn in the same way as a tyre would. One of the biggest issues with lowering springs is that they are stiffer and suspension travel is reduced and so the existing damper is overwhelmed.Ā
I would suggest that Meister or Gaz will give you what you want but stay with 350/250 springs.
[/quote]
[/quote]
Come and see us all on the mazdamenders stand and weāll bore you death on all things Roadsters, Nick is next to us to, so it is a win win, we donāt do bull, iāll bring a set of meisters CRDās with me so you understand what we are biging up buddy, and as said Speedy will take you out on a thrash, i will be helping with the clubs comps judging first but all free after that.
I donāt think there is; Protech have apparently updated the internals, and now has a better coating (subjected to NATO salt spray testing). Problem is the springs; Phil got the pigtail springs from some other place, and I donāt know the ratings. So if you are trying to replicate the original Puredrives from scratchā¦
That was sort of my thought⦠Lowest spring rates Protech offers are 325/225. Iāve had GGPs on 350/250 in the past; Protech also offers those rates (and many firmer), which I seem to recall was Philās choice for the Sportdrives, but Iād be tempted to go that bit lower. May I ask what top mounts youāre using? And what about dust boots?
Talk of different internals might defeat the point, though, if it changes the way they behave.
For the reference of anyone else contemplating the same thing, I found a comment from Phil elsewhere confirming the Puredrive spring rates at 350/250. The pigtail design of the springs may also have an impact on the behaviour, though, as theyāre supposed to reduce coil binding (I have no idea how true this is, but I can see how it might make sense); Protech sell their version with straight 2.25in ID springs. I actually happen to have some 350/250 pigtail springs from Gaz, so maybe I could use those. The Protechs currently appear to be on sale at Ā£508 a set, with springs but no top mounts, etc. Tempting.
For the benefit of the original poster, my car is currently on new OEM spec springs and dampers ā which do indeed deliver genuinely decent fast road behaviour. I bought this car on KYB adjustables with standard springs (pretty horrid in rebound), and have subsequently fitted mk2 Billies and fixed height Gaz before returning to the pseudo standard set-up Iām using now (I have mk2 top mounts and Fat Cat Motorsport bushes). Am also seeking fast road behaviour, basically; I only want to change again because I see the value in height adjustability as well as perhaps being able to fine tune the damping to taste. Previous cars have been fitted with Gaz Gold Pros (thereās a long thread on here somewhere about my initial experience with these; got them working satisfactorily in the end), and Iām currently trying to decide whether to go with MeisterRs or something else. Really Iād like to try a car with the Meisters fitted before committing ā Iām slightly dubious about their spring rates, but have been told the independent preload design of the Meisters changes the usual formula for this. Iāll be at the rally on Sunday, hoping to ask a few people about these and other options.
There might have been some guff about binding of springs, but the reason is so you can use Mk2 top mounts with standard perches. Phil offered an option of a perch to take a standard Mazda diameter spring as well, not sure anyone took him up on that.
A comment from IG Racing was they always buy their Protechs and GAZ shocks ādryā; with no oil in them, and assemble/fill themselves. Most of the failures they see, whether its GAZ, Protech, Shcktec, AVO, are down to poor factory assembly (swarf), because the design is basically good for the price (theyāre all evolved from a Rod Avon design).
I think one has to be realistic about the capabilities of any shock-spring set retailing for £500-600; this is at the budget end of the spectrum. The choice is over budget shocks made here or made in the Far East. I wish I knew who actually makes these Chinese/Taiwanese shocks. I can look at Alibaba, and see maybe a dozen Chinese/Taiwanese makers making shocks that look vaguely similar to the shocks being sold here. Raceland are imported cheap TUV certificated shocks, but not these others; not sure why. The certification is done by TUV in China, not here; its not an approval certificate as such, but more of a manufacturing conformance (ie two sets of Racelands are equally crap), and indicates if the manufacturer has got processes under control.There are different tiers of manufacturers in China; the best are the manufacturers who supply to Ford, VW etc in China. There seems to be an enormous different in car parts factories in China
Feel sorry for anyone trying to source from China. Yikes
Just as a follow up to the thread, I took a ride in Ian (Speedys) car at the spring rally and was really impressed with how the car handled on Meister Rās. I ended up ordering a set of the new Meister CRDās and spent Saturday on my back fitting them. Took a drive up to the dales yesterday and in my opinion the handling of the car is completely transformed! Bear in mind I was on lowering springs on standard shocks so for me this was a huge step up.
YMMV obviously depending on where youāre currently at on your setup but I for one am extremely impressed! Currently the car is set at 310mm front and 320mm rear with 5mm of preload and full soft until the car settles into the springs, then itāll be off for a full geo setup and Iāll start tinkering with spring rates and damper settings.
So far even on this vanilla setup the car handles superbly. I probably drove it a bit too hard in the dales yesterday considering itās settling, which is testament to how much confidence a good suspension setup provides!
Big thanks to Ian who took the time to chat and offer me a ride and proffer his advice, also thumbs up to Adrian Flux who didnāt even ask for extra money for adding on my new suspension and wheels!
Iāll stick up some photoās soon and let you know how I get on once itās settled in properly and had a geo setup done.
