I cant upload any pictures 😫
Advised maybe? I need to pass some sort of verification?
Upload processing?
It takes like 15mins and nothing?
Maybe i should wait longer?
Only been here 24hrs
I’m sure you have to be on the Forum for a certain amount of time, verified by Admin, or something along those lines.
Someone will give you the definitive answer.
Yes, it might be due to your current user account status. Try making a few more posts around the forum, then try again.
Cheers :clinking_beer_mugs: I will keep chatting to build up trust :+1:
Appreciate the feedabck :100:
I’ve occasionally had the same problem. Sometimes loading one at a time seems to work better than trying several at once.
Cheers mate :+1:
Il keep chatting rome wasn’t built in a day :+1:
Thanks soon get my pictures up :ok_hand:
Are you trying on a phone/tablet, or laptop/desktop?
If the latter, you should just be able to drag a photo in when you’re writing a post and it’ll upload in a couple of seconds :+1:t2:
Still, probably best to get to 10+ posts and then try then - rules something else out :slight_smile:
It could be you are not a full member
Maybe that would fix it, I feel it’s time to do some deeper digging :thinking:
I just asked the question, in case someone could point out whats happening, seems a tricky question.
1 Admin may need to check me out.
2 Following a certain amount of post :closed_mailbox_with_raised_flag: or reply’s
3 full membership
4 good old time to pass
Thanks for the suggestion :+1:
You don’t need to be a full member to upload and post images on the forum. That’s not the issue.
The forum software is the best I’ve come across for easy uploads so suspect your end first.
Hi, I just tried to uplaod, it gets stuck?
How long does it take to upload for yourself?
Uploads are working fine from the forum perspective.
You do need to allow the images to fully upload before committing.
It normally takes a few seconds, depending on bandwidth.
For the image above this (below) is what is seen in the composer (markdown not rich text option) when the upload is complete and before committing the post.
You can see it uploading. Typically 2-3 seconds.
Thanks :blush:
Im clearly locked out atm, nevermimd.
Im sure I can wait until it unkocks
Ive waiting for 15mins before now.. oops
You aren’t, your account is no different from anyone else’s when it comes to the right to upload pictures. There must be something at your end which prevents upload, what device are you using and where does the upload fail, what error message if any do you get?
You have managed to upload a background picture for your account profile so it has worked.
Wouldn’t be that the files are too big would it? :thinking:
Processing: 1000038140.jpg..
This is the message I see, seems to just sits there, I can wait but nothing changes, shame as I use my phone Samsung s21
Ps I will try again and leave it.. cheers :clinking_beer_mugs:
Ha!! Did it work?? It did it I believe :folded_hands:
Ive had the same but most of the time its when i try to load more than one photo at a time. It seems to work a lot better if i just do one then when thats loaded i do another.
