I replaced my window regulator on my 2016 ND
Hi
The one mentioned in the thread above. I assume there is one in the passenger side door for side impact.
Found it online now thanks.
I’ve just replaced the LH reguulator and the window went down when closed the door but now i can’t get it to do anything. Tried the reset procedure but nothing at all happens with that window? Any other ideas?
Which reset procedure did you follow? Seen this?
Yep that’s the one. Only option I have now is take the door card off and disconnect the power connectors, then put it all back together and try again!
Got it working fine this time!
Using that procedure?
Only after i took the door card off , disconnected all the connectors and reconnected, which got the window moving , then i could use the procedure!
