I went a bit silly
My 2016 ND 2.0 (16k miles) has spent a bit of time in a local tuners and has had…
Meister coilovers
6 pot front brake upgrade
Edelbrock supercharger + Fab9 tune
Manifold + full exhaust
Strut brace
and the rocker cover powder coated to match
They had to fit some spacers to get the wheels to clear the brakes which generally I’m not keen on but have to say, it handles a lot better than it did. Much more stable turning in and nowhere near as skittish feeling on slightly lumpy roads. The supercharger is pretty uninvasive (is that a word?) until you really get going which is what I wanted and the custom exhaust is subtle (I wanted it as close to stock as possible as too old for making a lot of noise) but has a lovely note to it when under power.
Overall, pleased with the spend!
Unable to see your photos!
What did the dyno printout look like? I can’t see the photos either, so that might be one of them.
If you would recommend the tuner, please can you let us know who did the work?
Mark, Sadly, your photos aren’t visible :slightly_frowning_face:
Sorry, Imgur links all going wrong for some reason. Replaced with an upload, hopefully it works now.
C Your Photos…no problemo
I like the look of all them mods etc the new seats …!
Hi there … what is the bottle to the right of the washer bottle ? mine doesn’t have that :thinking:
It’s the radiator expansion vessel
I’m afraid my memory isn’t good enough to recall if it was moved as part of the supercharger install!
The radiator expansion bottle is still in place, so cant be that.
Looks like a it has a charge air cooler and that’s the coolant tank for it.
