- My model of MX-5 is: RF skyactive Nav
Has anyone one successfully fitted the vintage look illuminated sill plates from mx5 parts. The wiring on the instructions doesn’t match the wires in the LH foot well As described. There are a number of green wires and I don’t know which to use.
Hi G,
I have fitted the footwell lights which will use the same pick up points and found it difficult to see which of the green wires to tap into.
If you would like me to take a picture of my car where the wires are I can do it tomorrow. I can also draw the plug/wire layout.
I was also reluctant to tap into the wiring and researched until I knew what I was doing. Unfortunately I can not get that information to come up hence my offer of a picture.
Hi G,
I have found the diagram of the plug. If you send me a private message with your email address I can send it to you.
Hi there Mad_maic
Thanks for the help
