Hi all,
It’s been a while since I was last on here - a testament to the fact that our ‘5’ has been behaving itself very well
However, about a week ago we started experiencing problems with the indicators. I’ll do my best to explain what’s going on but bear in mind that this is an intermittant problem. The car is a 1998 1.8iS Mk2 (UK-spec).
Upon starting the car for the first time during the day everything is fine and all systems work. Sometimes it’ll remain fine for a few days but sometimes the indicators fail at a random point during the drive - this could be 2 minutes into the drive or after an hour, etc. Neither the directional indicators nor the hazards work. The stalk still “clicks” into position but you can’t hear the solenoid clicking in time with the indicators flashing and the indicator lights do not light up at all - it’s as if the whole indicator system is dead. This is the case for both front and rear indicators (as well as the side repeaters).
I’ve investigated the fuses - all are fine; I’ve investigated the wiring runing from the indicator stalk to the block below it and that seems fine too. Wiggling the wires does not bring the indicators back to life either. The only way we can get the indicators to work again is to turn the car off, leave it off for a couple or minutes and then restart. 9 times out of 10 the indicators will work again until the next time they pack up.
Before I take the car to the dealer I was wondering if anyone on here had experienced the same problem or whether you have any advise as to (a) what it might be or (b) how to resolve the issue.
All feedback is gratefully received
Kind regards,
Dan
