- My model of MX-5 is: __2019 RF ND2 (at 42,000 miles)
- I’m based near: __Horsham
- I’m looking for technical help or recommendations on: __belt squeal
For the last week ive started hearing the occasional sound which i think is belt squeal/slip.
What’s odd is that it doesn’t happen on cold start or in general under load but most often at low to no throttle especially when you lift off the throttle.
(Occasionally if you are booting it hard up into the higher rev range i think it occasionally happens here as well but my cars quite loud so hard to be sure
It doesn’t happen all the time only occasionally and despite a number of test drives its strangely hard to reproduce reliably
I’m assuming it either a belt or bearing showing signs of wear but would be interested to hear peoples opinions/experiences with similar sounds
Just for reference : about 5 weeks ago i had a Rotrex Supercharger installed by BBR GTI (first customer apparently on an ND2 - yikes!) and its been fine for those past 5 weeks.
This included : BBR spec revised ancillary belt and tensioner
NB : ive also asked BBR for advice but heard nothing back yet
