- My model of MX-5 is: NB__
- I’m based near: __
- I’m looking for technical help or recommendations on: _Jenvey_ITB fitment
Hi folks.
A chum has just sent me a link to someone selling a set of Jenvey ITBs
The advert says they fit the 1.6 but would they also fit the 1.8?
Thanks in advance.
Guy
Probably not, the head is “longer” on the 1.8 so the stud spacing is different, assuming they come with a “manifold”.
Thanks Robbie.
Much appreciated
You only need a different manifold to correctly space them and the 1.6 one could be sold on.
The kit may include a tps whilst your 1.8 has a vtps but again solvable.
Check that the kit has;
Linkage
Vacuume block and lines
Air horns and an air filter
Injectors and a fuel rail
Blanks for your OEM injectors
An ECU, what plugs does it fit and what type
You will still need ;
Gaskets
Assortment of hoses
Coolant and probably worth doing oil change at the same time and new plugs
May need new throttle cable
May need tps
Thanks Mark.
I didn’t bother buying the ITB’s but the information is good to know incase any ever crop up again.
Cheers,
Guy
