- My model of MX-5 is: Mk3.5 PRHT 2.0i SE BBR Stage 2
- I’m based near: Glasgow
- I’m looking for technical help or recommendations on: BBR info
Hi all, I have just bought this and need get it fettled to my liking.
It was a probate sale in the past so I don’t have any of the BBR documentation.
I’m very familiar with Mk1 s and spannering ( I have had a supercharged Mk 1 for 26 years) but know nothing about Mk3/3.5 and at bit less about turbos, so any help appreciated .
The installation was a DIY installation with ( as far as I know) a BBR map ( the pop/bang version) .Kit was fitted 2019
Here goes with the questions, I’m sure there will be more
does anyone have a copy of the BBR DIY install instructions they could share , so I know what goes where and what is OEM vs BBR .
engine top cover - the engine cover is fitted ,but the 2 rubber grommet posts next to the plugs are missing , so it is held on by the single spring clip only . There are no studs for the grommet posts and no sign of a place for them - is this as a result of the BBR mods ?
- wire coming from l/h ( passenger side) connector below the inlet manifold - connected with a screw block and disappears…any ideas ( am assuming BBR related)
another wire spliced at the front of the fusebox - may be the other end of the same wire but not sure …
does not have a strut brace fitted - I think the factory strut brace should fit with the turbo , but I’d like confirmation ( I know I will also need the bulkhead plate with the brace mounts)
this bracket is loose. ( the one with 2 holes and nothing fitted to it in the pic .I assume something was removed for turbo fitting and i can remove the bracket
If there are any other Mk3 BBRs in central Scotland happy to meet up and compare notes /kick tyres ![]()
Probably more questions to follow once I get a proper look at it at the weekend.
thks
Jim
