k and n typhoon
im fitting the k and n typhoon induction kit and having a problem with the air temp sensor there is a bung that it supposed to go into but it doesnt go in has anyone else fitted one and can sugest something , thanks guys
Have you got the whole sensor out the old air box.
I made the same mistake when doing mine. Pulled out the sensor but found there was an extra plastic bit inside the airbox that it had attached to. This also comes out and attaches to it. Should fit nicely into the bung with that bit attached
ah that could be it thanks will check in the morning , i was very annoying i dropped the bung twice and had to undo the rad to retrive it i was spitting feathers thanks for your help
I had to put the sensor into the supplied bung first - then fit into the intake tube. It wasn’t a tight fit so I then had to bind some insulating tape around the sensor, push into the bung, then into the intake tube,this made it a snug fit!
The sound of the induction roar is glorious!!!
ENJOY.
