Hi All I thought I would share this with you all, I bought a K&N oiled panel for my MX5 Mk3 2008 2.0 sport, it did make a difference to the sound and it also felt like a performance gain.
I then read reports about oiled filters causing issues with the air sensor (MAF?)
So I bought a non oiled piper cross. The similar induction sound as the K&N but felt it had a better performance gain over the K&N.
Most of the performance gains on forums generally dismiss performance gain as just better sound, however there is not much difference in induction sound between the K&N / Pipercross.
It would depend on the condition of the filter you took out.
I would be surprised if there was much if any noise difference if you are literally just swapping a filter in the air box without making some change to the intake system.
Some 10 years ago now ITG did some rolling road tests on my MK2.5 with a very fancy Maxogen set up and at best it made 2bhp, which is well withing the error that a rolling road would give. The K&N Typhoon was tested at the same time and that made a 1bhp lose, but again well with RR tolerances. The conclusion was, the noise was great.
Personally I felt the car was freer at the top end so would run to the read line more easily, figures didn’t “prove” it though.
I fitted a pipercross, no statistics but I would say slightly louder induction, and maybe a couple HP more, but maybe thats just my imagination. Sticking with it anyway.
I swapped a new 3rd party air filter on my '07 2.0 sport and noticed it was freer revving to the red line and sounded much better. I stuck with the pipercross for the next 2 years
Then I bought a '13 2.0 Kuro and swapped a dirty oem filter for a new oem filter. The car sounded better and revved freer.
I then swapped the new oem filter for a freshly washed and oiled pipercross and the car sounded flatter and the noise was a bit duller. I put the new oem filter back in and am sticking with it because it feels just right. I did notice that the design of the oem filter has changed very slightly and it now has a blue rubber gasket around the edges.
